EFI Fuse Blowing!!!
empera
Authorized Vendor
Philly.
ok theres a short in my EFI...was drivin back home from the races on i95 and all of a sudden my RPMs just dropped to 0...couldnt do shit, so fortunetly the car had enough momentum* to make it off the highway...so i look around cant find anything...call dave (jerseyslowpra) comes down and he finds that is a fuse, i did check them but not as good heh, the EFI fuse, we try replacing but keeps blowing... We spend so much time looking for a short or some bad grounding, couldnt find anything. So any of you have an idea on where the short could be? Right now out of desperate measures the fuse is hot wired and there was no fire or smoke??? I have no idea wat could be causing this problem.
chevyeater
wastegate hose is pulled
Long Island, NY
Look close around the EGR tube at the back of the intake manifold. The harness can get pretty close there and if the one little plasic clip breaks, it is laying on the red hot pipe, melting thru.
empera
Authorized Vendor
Philly.
i unplugged the o2 sensor then tried it again and worked, then plugged it back in
