Ok I took it out for a really long drive of about 90 miles and my turbo timer work great with my factory alarm system w/o setting it off when shut down. However I went back to redo the spd wire, basically remove the crim and splice the wire directly in, and when it fire up the car idle at 1500 and then drop to 1100 and back and forth it go from 1100 to 1500 rpm. Anyone know what could be wrong with it? I checked the CPS wire and the TPS wire to make sure it's not loose and it still does it w/o giving out any code. I turn off the TT and remove the wire from the harness and it still does it. Mine is a 91 turbo and for some reason my TIL (turbo indicator) pin on the harness is empy. I have 3 empty spot next to the +B1 instead of 2 like the TSRM showed.
