help!!! my car is slower on boost than it is off boost! I swear it pulls harder before the turbo spools. I am throwing no codes at all!!!! It has 93 octane in it, and it does this at stock boost or 12 psi. Everything under the hood is connected, both knock sensors are hooked up, no boost leaks, its not pinging that I can hear. It just started this today. Any ideas? When the turbo spools, it will pull hard for just a second, and then the ECU pulls the crap out of the timing. I threw a timing light on it at work, and its at 10 degrees btdc...
