Ecu Clinking
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Just like the title says I have this weird thing going on. All of the sudden my car doesn't want to idle, usually after I've driven it a while, shut it down and then restarted it. What happens is the idle starts bouncing around and then it feels like it going to stall and the whole time I can here a clinking sound under the dash which I presume to be the ECU. Could it be the Idle control valve and why would that cause the ECU to make the clinking noise?
It's not vacuum cause I have a vacuum gauge and it seems to be steady, so I am stumped. I can keep it running by fanning the throttle but it also hesitates while I'm cruising at speed on the freeway.
Any help would be appreciated.
kewlcoconut
47
Vancouver BC. Canada
suprabad said:
Just like the title says I have this weird thing going on. All of the sudden my car doesn't want to idle, usually after I've driven it a while, shut it down and then restarted it. What happens is the idle starts bouncing around and then it feels like it going to stall and the whole time.
I have that EXACT problem. Although, I haven't heard a noise with mine. I should listen more carefully. I have had this problem for almost a year. And I know it's not a vaccuum problem as well. I honestly can't find out whats wrong with it. I need help on this as well!!!
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I don't think it's vacuum on mine as I have a gauge and it doesn't seem to fluctuate, although I haven't eliminated the possibility. Somebody out there has had this prob, C'mon somebody help us out...please.
IHI-RHC7
"The Boss"
Oregon
Check the elevtrical connection to the ISC,
The clinking you hear is probably a bad connection on one of the relays in the passenger side kick panel. When a relay has a poor power source or ground, it can engage half-way, making a grinding, clicking noise.
-Jake
