Ebay turbo kit?????
pearlwhite turbo
booost'nnnnnn
Oct 8, 2006
55
philadelphia
I'm just wonder'n about this ebay turbo kit's that come with turbo, intercooler, manifold, wastegate for like 600 bucks. has any one tried this? I'm upgrading my turbo with my build and am looking for some options.
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
Someone did end up buying it but he hasnt given us ne feedback on it for the past 2-3 months.
but i still wouldnt get one, i just dont trust ebay. Unless hte person is on SM or SF and well known.
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
search for egay not ebay egay and it should come right up
supra90turbo
shaeff is FTMFW!
32
MA, 01440
The SSAC T70's are as good a turbo that you can buy new for $300
that said, with proper break-in procedures, they're not bad turbos.
Use them at your own discretion/expense/luck?
Some people have had good luck with them, some bad. It's all in the break in, and I really think that you should add an inline filter to the feed line as well.
For turbos that are good and inexpensive, check out Master Power turbos, and sell the XSPower/SSAC turbo for a couple hundred.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I'm with Kurt. I'll be running a Master Power T70 on my 2JZGE, it definately looks quality. Unlike others, I'll report back with details on it.
935motorsports
San Diego, CA
We are using a T70 locally. However, I had it rebuilt and balanced before using it. The builder said the balance was decent, but the bearings used in the turbo were no good and probably the cause of premature failures.
We sell the T70 completely rebuilt with warranty for $500.
loki2043
645
Portland, OR
so are you saying that it come with shitty bearings? so after you replace those its a good buy?
RHDMK3
that's it!
Sep 30, 2006
447
Salem, Oregon
SSAC uses Garret turbo's I believe in there kits. The problem with their kits isnt the turbo, but the manifold. A lot of guys on this Honda forum I post on have or are using SSAC turbo kits. No problems with the turbo itself but the manifold's tend to either start breaking at the welds or crack under higher boost (8psi+). Plus I hear that SSAC has some serious customer service problems. I lot of people that I've talked to that have had problems with said kits try to call the people at SSAC only to get the run around.
illmatic357
in me soarer rip my mk3
Aug 2, 2005
138
Milwaukee
well i have the "official ebay setup" turbo, manifold(modified version 2) and intercooler and wastegate
all i can san is the car os going to be fast for a long period of time i hope if not u will here from me
pearlwhite turbo
booost'nnnnnn
Oct 8, 2006
55
philadelphia
Keep me posted, Is the manifold sound?
illmatic357
Aug 2, 2005
138
Milwaukee
well i had to cut the last runner on the manifold to get it to fit with any clearence issues but i have also welded an tial wastegat flange to it now i just have to get a wastgate but im so busy building my sc400 i have stopped with the supra.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
I've installed one of those turbo kits on a GSR and I am currently running there manifold the kit is missing little stuff that your going to need like lines hoses and etc. heres a pic of the kit I installed.
Also do not purchase your vacume hoses on ebay there cheap and there very poor quality.
Remeber to PREP the turbo or atleast on the first start up to hold the wheel on the cold side with your fingers for atleast 40 secs, then let go
WARNING: After it starts spinning dont touch the wheel.
