how bad will this generic ebay stuff hurt my car
http://cgi.ebay.com/ebaymotors/Toyo...024QQitemZ370064404239QQrdZ1QQsspagenameZWDVW
ForcedTorque;1067440 said:.......... but I wouldn't trust anything else, not even new name brand stuff.
***EDIT***The dude has 46 negative feedbacks in the last month!!!!!!
sethron71;1067418 said:Just a quick list before I go:
-IMO 1.06A/R is to large, gonna be very laggy unless you have a very heavily built setup to help spool or are using nitrous. Basically not a street setup at all!
-No bead rolled pipes and usually thing silicone couplers, Also 2.5" is too small for that turbo, you would need atleast 3" for 1000hp!
-Knockoff/replica BOV
-KNockoff/replica wastegate, I have used
-Manifold looks to be the one that hits the oil housing, maybe wrong but my #1 runner is tucked more, again I run one of these on one of my cars. For the money you can't beat it but still not the best for flow!
-Turbo timer is again a knockoff/replica
Of course this is just my opinion and this is coming from someone who has used some of the stuff. As I recently learned, there are things that are vital, fuel/electronics that need to be perfect but you can use the knockoff stuff elsewhere if you choose. I personally think there are a lot better parts out there but it is always your choice. But don't expect any kind of warrantee or custom service what so ever. Also expect a good bit of custom work. Like it says not all fittings are included, but also, DP, intake, mounting IC, building the IC pipes, running all the lines, dump tube, oil and coolant lines....ect the list goes on. If you are interested and have the money to do it twice, give it a try and write a review I am sure everyone would love that!
Remember these are only my opinions!
Seth
suprahabsfan;1067685 said:46 negatives!!!!??? isnt that grounds to be removed from ebay?!
Mk3runner;1068282 said:57 trim is best to go around...
