Ebay Brakes
tissimo
Stock is boring :(
Melbourne, FL
I used a set similar to that on my old 2jz swapped 91 car. and they worked fine. Just be sure to check the rotors every so often for cracks as the drilled rotor will eventually crack.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
that last hole is drilled WAY too close to the edge for me to run those... spend some good money on brakes, they'll save your life one day.
a2motorsports.net has good deals and they price match.
Drilled and slotted is pointless...
One or the other, and slotted tend to not fail as easily from cracks.
This is all pointless to really talk about as brakes is the WORST place to be cheap on. It is the one thing that if it fails will more than likely seriously injure or kill you...
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
my dad bought a set of drilled brakes for his Saab 93 (a daily driver, commuter, pusts 170miles every day on it) and he LOVES his drilled brakes, BUT... theres at least a full 10-15mm gap between the edge of the rotor, and the last hole... and belive me, hes had to stop from 100+ to 40 and 50mph pretty quick and it works NICE.
but he also spent the money for QUALITY rotors and QUALITY pads....
dumbo
1,911
Albera, Too Far North
isn't slotted really only for racing apps.? doesn't the slot shave off the glaze on the pads or somthing? and it reduces pad life i thought.
