Eastwood's fender roll
nitroneon85
58
Ohio, USA
Had a question if the fender roller tool is strong enough to roll the rear double wall lip on the MK3? Any tips or problems anyone's encountered. Thanks for your time.
not sent from my iPhone 5
Yes it is.
Make sure to use a heat gun on the paint so it doesn't crack. Unless your paint is already bad.
Also you want to bend it a little at a time. Don't try to make the lip flat in like 3 rolls.
nitroneon85
58
Ohio, USA
Yeah, I'm doing a complete paint job. Thanks, cause I read directly on Eastwood's website that it doesn't work for quote "dual thickness flanged fenders, mostly found on the rear of full size cars". So I'd figure ask the people that have actually done it. Thanks Hvy
#04
526
Cambridge
I've seen it done wrong more than once.....
you really only need to roll from somewhere around the 10-2 (if the wheel was a clock) this should allow you to leave the moulding area's alone.
for me the roller got me 80% of the way there, then hammer and dollie, and little hand adjustments (front)
for my rears I planed on filling the rolled metal with seam sealer to avoid water permeation into the quarters in case I broke the OEM seal, which typically fail...
projectsupra
旧車スープラ
West Palm Beach, FL
s235.photobucket.com
I believe dual thickness refers to a gap between the inner and outer sheet metal such as the 4th gen firebird/camaro, this will cause a problem when trying to roll flat.
How much work you will have to do on the A70 will depend on ride height and how aggressive your wheels are. I had to roll, pull, and trim the moldings for no rubbing.
