Easies way to changing an oil pump??
supra_89_vang
95
madison
Hi,
What is the easies way to change an oil pump (engine still in the car)? I want to change the oil pump on my 89 turbo and was wondering if anyone can tell me the easies way to change the oil pump?
HOW DO YOU REMOVE THE OIL PUMP??
I try removing the oil pump but I am having problem get the crank pulley off because it was rusted. For supra's, can you just open the oil tank and remove the oil pump? Or do you have to remove the crank pulley, timing belt, oil pump shaft, etc....??
Thanks
N
NDBoost
Guest
w/ 3 sets of supra hands you can pull a motor in under 2 hrs. If you work fast.
