E Brake question.
Hobbes992
65
Tampa, Florida
Ok guys,
I have an 89 na 5 speed. My ebrake refuses to work. Essentially, I can pull up the handle and hear the clicking but no effect. Do you have any recommendations? I know the ebrake gets applied to the rear discs, but should I check the adjustment of the cable at the handle first?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
It's worth a try. If that doesn't help check the cable under the car next. If everything's intact and present, pull the rear rotors and see if the pads need replacing.
CRE
Oct 24, 2005
3,485
Denver, CO
Hobbes992 said:
Ok, I guess I'll try that. Thanks
Hopefully, it's nothing like my passenger side was... Someone had taken it completely apart and apparently decided they didn't know what they were doing just scooped all the loose parts into the drum. Needless to say that I've got an entirely new ebrake on that side now, I had to replace everything.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
I got an e-brake question too, relating to the thread, I don't think I'm jackin this thread...I hope.
I wanted to know how hard it is to replace the e-brake cable. Is there a write-up or diy anyone knows of. Or does anyone know what steps it entails? The e-brake on my car doesn't work and I'm not quite sure how hard it is to do the job myself if it is the cable. Of course if it comes down to it or if it's way beyind something I wanna try then I'll take it to a shop, but I wanted to try it out, do it myself.
CRE
Oct 24, 2005
3,485
Denver, CO
Depends which part of the e-brake cable. The front half is easy, doing the rear on mine sucked big time. I don't know if there are any how-to's, the worst part is the cable sleeve's fitting which anchors into the knuckle. There's probably a tool that'd make it easier, but I don't have one.
If you decide to tackle it yourself do one side at a time so you can refer to the opposite side when reassembling everything.
If I had to do it again, I'd pay a shop. Mine was worse because I had to replace *everything* including the knuckle. The TSRM does have a break down, but I don't remember it being any help.
