E-01 and maft-pro running together
josh930
247
NY
I know they cant interact with one another but is there a possiblity that I could use the maft-pro(the $400 one) to loose the afm and tune while using the the e-01 profec boost controller for boost with wideband hooked up? Or will it be harder to tune than just going with the maft-pro(the $700 one). I'd like to keep profec because I'd be lucky to get $300 for it and thats just as much as the "extras" package from maft pro. Basically, do I need the boost and fuel management running together in order to tune? I wouldnt think so but just want an opinon.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
im not that familiar with the e-01 but i dont see why you cant use the maftpro and the e-01 as long as you dont get the boost control package. i dont think the two have anything to do with eachother. someone correct me if im wrong
josh930
247
NY
Thats what I thought. I just wanted to ask to be 100% sure. I would only have to get the maft pro with speed density to get my setup straight.
josh930
247
NY
I have the plx with display. I'm just going to stick with that. Its already hooked up to my E-01 to graph it with my boost.
josh930
247
NY
Its a nice setup. If I recall it was cheaper than the lc1. The main reason I went with the plx is the compatability with the e01.
josh930
247
NY
Yea, I already have the blue emanage but exactly what bowsercake said, it wont eliminate the afm.
