Well, I had a dyno appointment and these are the results I have with the Horsepowerfreaks Turbo kit utilizing the Precision PT67 with .68 A/R P-Trim Turbine at 22psi. The turbo was barely breaking a sweat. I have another pump I will be installing shortly and hopefully will have better numbers to report in the near future.
518.25rwhp
491.1 rwtq
Below is the dyno run. The dyno was done at Torquefreaks, but the runfile was viewed on the viewer at work so it says "Extreme Turbo Systems". If you would like to see a write-up, you can visit 7MPower.com for more info. Of course, AFTER it is updated..
I just sent the updated information this morning to the new 7MPower owner, so hopefuly it will be updated shortly.
518.25rwhp
491.1 rwtq
