dumping oil on radiator...
N
NDBoost
Guest
its time to figure why your spraying OIL all over the place
jdub
Feb 10, 2006
10,730
Valley of the Sun
LOL...that would be an outstanding idea :aigo:
And I'd check your oil level if I were you...like right now.
N
NDBoost
Guest
Or hes got failing rings or valve seals damn pcv system...
supra90turbo
shaeff is FTMFW!
MA, 01440
Rings, causing excessive blowby, causing excessive oil vapor in pcv system, thus depositing it in the intake tract, and then through the intercooler pipes, intercooler itself, then out the bov. so yeah... rings. ;)
supraguy31
626
Pembroke, NC
Are we talking about something like this.......Oil coming through that Metal pipe at the top of the Pic.
lagged
1991 1JZ
new rochelle
doh!
:icon_bigg
monkihead
driven to thrill
Jul 23, 2005
93
texas
can't be rings, engine has 70-80k miles on it. turbo has 175k++ miles.
already pick'd up a spare turbo for 100$. has 30-40k miles on it. no shaft play.
rakkasan
Currahee!!
Fort Campbell, KY
I'm guessing here, but I assume that you bought a JDM motor? If so, it very well could be the rings. For all you know, that person that dropped the car it was removed from at the junk yard it was *harvested* from could have dropped a bucket of sand in it before hand.
Moral of the story: don't assume, troubleshoot!
monkihead
driven to thrill
Jul 23, 2005
93
texas
its not a jdm engine. it didn't need the oil pan gasket or timing belt but i wasn't about to chance it.
so ya'll feel that having small sprays of oil coming out of my bov would be rings? usually oil will burn at idle to mild throttle and letting off. leaving it to rings and valve seals to investigate.
cartman
7m powa
Jan 29, 2006
Chilliwack
did you ever leave your oil cap off and forget to put it back on? I've seen that happen before and the oil sprays up onto the hood blanket and drips down in weird places.
