so im thinking aboout going this way in a while, im just wundering if anyone here has done it and what i might need to do it other than the 2nd fp.
boost fiend said:id like to see the pics please. as far as power im at about 399.xx now. used to be a little more but i sold my boost controler to save my hg till i put another one on in a month or so with the new turbo. im aiming for about 500hp.
figgie said:well
math should answer that question
255 lph = 4250 cc per minute.. this is at what ever the rated flow of 255 lph is at.
4250 cc per minute max
so we take that number and calculate
(4250cc/min / 10.5 ) / .5 BSFC hp = 809hp MAX at 255 lph. Now keep in mind that if i recall, the 255 lph is a ZERO psi (ie free flow). That number drops with higher PRESSURE.
ninjaedit: thanks the Grand National guys
http://www.gnttype.org/techarea/fuel...Graphsmall.jpg
so with this new information
200 lph @ 45 psi = 3333.33 cc/min
(3333.33cc/min / 10.5 ) / .5 BSFC hp = 634.92 hp.. keep in mind this is CRANK power at 45 PSI now
figgie said:why?
how much power are you putting down that you need a 2nd fuel pump???
tubbie said:Redundency??
