DSM Fans
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
True, any electric fan will be better than the fan on your a/c clutch. Check out my for sale thread, I have a 15" electric fan that should push a ton of air!
-Chris
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I run the DSM fans, they move a lot of air.. but you'll need something to control them with (IE: temp switch/relay; thermostat control unit; standalone/relay).
stealth
San Francisco
Yes I'm replacing the belt driven fan. I think my clutch is bad. Does anyone have pics installed? I should wire them up to pull air right?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
It's cheaper to just rebuild your stock clutch. The stock fan will last you another 15 years vs. however long it takes the fans to burn out. Do a search on how well the supra's stock fan flows vs. the electric fans...
jdub
Feb 10, 2006
10,730
Valley of the Sun
-Chris
Ummm...not true. The stock clutch/fan moves more than enough air for the 7M radiator. Replacing it with electric fans has to be done correctly (thermostat control, relays, shroud, etc) or you will have more trouble than it's worth.
