Dropping 7m in
Sep 10, 2007
482
Virginia
while the engine is out, i would replace the rear main seal whether it's leaking or not...new part peace of mind i guess.
Oil pan gasket and front crank/cam seals if you feel like it. A new water pump isn't a bad idea either.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
where in washington are yeah??
your replacing a 7mgte in an auto right?
make sur eyou push the torque converter back into the tranny before you pull the motor, this way it doesn't fall out and cause a mess, not to mention reuin the front pump.
