So I did a fair bit of searching, but couldn't find anything on this subject. Just a quick question. Which line does the driftmotion 7m power steering line replace?
It replaces the high pressure hose. That's why it is rated for 2000psi or whatever it was. The high pressure hose on your car is easy to tell from the others because it has the special crimp fittings from the factory. The other power steering hoses are just return lines (drain back to ps reservoir) and they aren't as high of pressure.
