driftmotion ct-26 manifold
irocznissan
109
nj
ok i know they have the manifold so u can use the ct-26. im thinkin of gettin 1 but the ct isnt in the power range i want. so the question is can u use any turbo that fits the 7m with it too. i mean the one that bolt on directly. i dont see why not. lol
C
cnewingham
Guest
You need to stick with the stock ct an go with a trim upgrade. I was going to get a greddy td06 and put it on in place of the ct as it is a bolt on, however Aaron said that there would probably not be enough room to fit. I am only looking for around 350rwhp and 57 trim will do just fine so that is what I have decided to stick with.
If you are looking for well over 400rwhp then you probably need to go with a full T series setup.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
A cheap t4 setup exactly like the CT26 kit costs exactly the same. The point of the CT manifold isn't for power, it's for reliable power of the same level as stock twins for those who blow twins every week.
C
cnewingham
Guest
That is only if you are starting from scratch. If you already have the dp and the ct then you save a considerable amount. The ct26 setup will also get you above what the stock twins will put down and more reliable. It really comes down to how big of a build you are planning. I purchased a kit from DM and it is great quality work (better than the ebay t04 manifolds) but I am not going outrageous with this build. Something simple, reliable and fast enough.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
Actually the kit is designed for the people that have an upgraded CT26 and downpipe that want to 1JZ. that way its a bolt on affair and you dont have to get rid of all the stuff you already paid for and lose out on money.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
How is the quality of the manifold? I am thinking that when my twins give out I could just get the driftmotion kit and a CT26 57 trim as I already have a suprasport dp and elbow.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Quality of the manifold? C'mon, it's Driftmotion. They put out nothing but good quality products.
Tim
regular member
Oct 16, 2006
272
CA
I am running this setup and their is a little room to run a bigger turbo on the ct26 manifold adaptor, but it will be close to the shock tower. Depends on the turbo, I guess.
The Reaper
Jan 10, 2006
1,909
Florida
hahahahaha AINT IT THE TRUTH!!!!?
man those stock twins are horrible. so bad that when i get my Insurance money im going single instead of repairing the body damage!
Tim
regular member
Oct 16, 2006
272
CA
good luck with the twins and have fun taking them off in the car when they blow!!:aigo:
The Reaper
Jan 10, 2006
1,909
Florida
very true
it does look odd.
thats why yota hid it so far down there on the 7M cause it looked out of place
