driftmotion 60-1 or to4z turbo kit?
redsc300
texas
i will soon be doing a single turbo setup on my 1j powerd sc300. i have decided to get one of driftmotions turbo set up. the only thing i am unsure of is which turbo to get. my short term goal is 400rwhp and full boost by 4000rpms. this will mostly be a highway car, with a few trips down the 1/4. would i be better off getting the 60-1 with the .70 hotside or should i just go ahead and get the t04z and be done with it?
S.A. supra
2,405
Buda, Texas
Where in Texas are you from? I had a 60-1 but it had a blown seal on the hot side so I bought the to4z. I should have it tomorrow or Friday I'll get back to you when I install it. What mods do you have? I have 550's, MKIV fuel pump, and safc. I know that the to4z is a bigger turbo so the plan is to buy some bc 264's to help push the bigger turbo.
redsc300
texas
i am in the dallas area. i am kinda leaning on more towards the 60-1. as of now the car is completely stock. i have been saving some cash for about 6 months and finally have enough to start doing some mods to the car. i will be added the dm turbo kit, a fmic, 440cc injectors, safc, supra pump, ngk wideband, and a full 3 inch exhaust setup. also lookin into trying to get some modded 2jz cams to work in a 1j.
S.A. supra
2,405
Buda, Texas
^+1 If you want to go 60-1 you should get bigger injectors at least 550's. The 60-1 is good for 500 hp and the 550 injectors are good for 550 hp. That would be a good combo for you. I just bought that TO4Z Turbo that is good for 650 hp so i would need to upgrade my 550's to some thing in the 700cc range.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
You'd be best off getting an aftermarket fuel rail and 670cc top feed injectors along with the Driftmotion fuel dampener bypass. I wouldn't trust anything over 400 RWHP on a stock ECU and SAFC. You'd be best off getting a standalone. Also, over 400 RWHP you're going to need either a 2nd fuel pump or 1 big one. I chose dual Walbro 255 fuel pumps for my setup for now.
customs
175
Edmonton Ab
Dylan JZ;1601785 said:
a TO4z would not be a whole lot of fun on a 1J.. full boost at 5k is rather lame IMO.
I agree completely. Full boost at 4000 is the most I would want a street car to lag to.
OneJArpus
2,798
Trust isn't the issue the tune is. My buddy pulled 576 on a 2j single with an SAFC n wideband IIRC. I'll have to talk with gonzy. As far as i know all he has is a wideband and safc2
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
440's would be good for ~400whp (approx. 80% duty cycle).
there are also plenty of folks putting down ~450whp safely through a 1J with 550's (approx. 80% duty cycle), Walbro or equivalent, and an AFC.
for anything above that, a standalone and bigger injectors may be needed..
