Anybody out there made some drawings (like CAD or someting...)for exhaust flanges, preferrably the turbo outlet flange?
JoeC said:give me a picture and i'll draw you one up. I'm an ACAD designer for hvac systems but have worked in mech. drawings all through school. If you take the flange, draw it on paper and scan it to scale and send me that picture, i can xref it into autocad and trace it for you. Then i can send you the .dwg file in a zip or however you want it. Then just give that to the cnc guy and he can throw it in master cam or any other cnc machine program and throw a toothpath on it and cut it out for you.
JoeC said:actually that is wrong. It would not be easier just to take them a sketch with dimensions. They would then have to do exactly what I just said, put it in a CAD program and draw a 10 second tool path for their waterjet. If you went to a cnc shop and gave them a ACAD dwg of the part u wanted and told them it was a flange and "to scale" with a few dimensions so they can double check your scale perhaps, they would probably bump your work ahead of 20 other people because yours will be the easiest to do since there is no drawing involved.
