Doing some chassis mods
Status
Not open for further replies.
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
This is not complete yet. I am debating on some minor details with it still, but in the end these will be powder coated yellow.
Tell me what you think. If its nothing nice I might not care:icon_bigg
-Sean
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
Don't know yet most likely around 40lbs for both sides. I will know more once I have them done.
I really won't have anything to compare these to as I have barely driven my car and its a hard top plus I'm installing a cage.
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
Poodles;916507 said:
do they actually connect to the subframes?
if not they aren't gonna do a whole lot of good IMHO...
Of course :evil2: however I do have to disagree with you there. I build alot of chassis bracing systems for alot of different cars and simply put the factory subframe rails lack highly in structure. and just reinforcing that helps in the overall feel of the car greatly. Even in front wheel drive configuration.
-Sean
shaeff
Kurt is FTMFW x2!!!!
10
Around
i'm curious if it'll actually affect structural rigidity or not. it looks to me that all the weight transfer would be directed through those little steel squares. are the bars tied in on both sides, or just one?
and if you're putting a cage in it, i can't imagine you'd feel the difference with those. looks cool, though.
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
Im stitch welding down the entire pinch rail. I want it to be as solid as possible.
those inside rails are damn near as thick as a truck's frame, and the outside rail where the jack points are is equally as strong...
I'd have to see a true before and after of what they do, but our cars aren't mustangs or f-bodies...
themadhatter
760
Vegas
nice work man are they going to be welded to the floor man on the other side?
on a side note its to bad no one makes some kind of bolt in subframe connectors for us targa guys
no easy way to make them because of the design of the car...
the MKIV guys have em though, but I believe they are weld in...
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
I have offered but I didnt much interest. There is no way I would make them off of my car though the under body was such a mess:icon_mad: I had to reshape the entire length of the pinch weld and the parts of the factory subframe So I'm going all out on it now.
Status
