does this sound rite to you?
uberness408
ex supra ownwer
May 12, 2006
66
california
today i went to the track and ran a 15.4 i have intake test pipe and i shimmed the wg (4 washers)every shift was 100 rpm away from redline and i used 1st 2nd and 3rd gears only launch was at 4000.
DaemoN
205
Wichita, Kansas
www.TeamFE.net
How much boost are you hitting with the 4 shims? I ran a ton of 15.3's and 15.1's at 91mph when I had my car at the track the first time (with intake, and mbc spiking to 12psi and slowly setting back to 7 by the end of the gear). I finally toyed with the mbc a bit more that day and got it to hold 12psi longer before it fell back to stock boost and I ran a 14.8 at 94mph. 2.3 60's on all of those lol. I was trying to slip the clutch rather than just dump it but I was still getting used to it.
tissimo
Stock is boring :(
Melbourne, FL
What MPH?? stock I went 91, shimmed stock exhaust i went 94-95, w/ an exhaust 10 psi i went 98-100
times were 15.1 stock, 14.33-14.5 shimmed stock exhuast, 14.2-13.9 exhaust 10psi
billspreston01
555
North Carolina
I run high 14's low 15's at 10psi all day long. 2.3-2.5 60's stock exhaust. Sounds about right to me. I've bested a 14.6 @ 98 so far.
Does the exhaust really add THAT much power?
uberness408
ex supra ownwer
May 12, 2006
66
california
my 60' was 2.4 trap spd was 90 mph i also forgot to mention i was running 40psi in all tires i dont know for sure how much i boosting but id say 10 pounds
8,894
Lower your tire pressure to factory specs if you are on a factory alignment with factory suspension.
I think the mph is slow for the light mods. Some cars are just faster than others. You may or may not have anything wrong.
