i have a relocated battery and i heard my local track is going to be doing more imspections of cars, jsut wanted to know whats needed to run a switch to the back i already have the battery relocated and such
shaeff said:heh, patience is a virtue. this board is the most helpful i've ever come across in terms of the mkIII. as far as i know, it's just a large kill switch in line with one of the battery cables. i know nothing about them, because i dont want one. (why? you ask?) because every time you kill power to the car, it re-sets the ECU.
i know you're probably only using it for the track, or to pass inspection for the track, but that's my reasoning, and i dont go to the track... perhaps someone else who's more knowledgable can chime in.
edit: ian beat me to it!
-shaeff
shaeff said:well, every time you reset the ECU, it has to relearn everything. it wont run "perfectly" until it's done re-learning. think of when you pull the EFI fuse when you clear the codes. think of how different feeling the car is.
-shaeff
