I am trying to track down why my rpm graph and my dyno results are so jagged. Everyone says it is ignition related. I have changed plugs, wires, cps, coils and set timing per tsrm. I'm down to the igniter. The one I have failed two of the power transistor test. Two other ones I purchased also fail the same two power transistors. Only IG2 signal passes, IG1 & IG3 fail. On 3 igniters. That is using the tests on IG-15.bigaaron said:Can I ask why even bother with the test at all? Just try another ignitor and if there is a change the ignitor is probably bad and if no change the ignitor is probably good. I have yet to see an ignitor fail in service on a 7m-gte, and I have worked on a whole lot. Not that it is impossible, but not very common. The only way it would be damaged is if your coil wiring was shorted to ground or a coil somehow shorted internally. Ignitors are so easy to get and the outputs are so simple. Just check the dc resistance of the coils and make sure the wiring has no shorts in it. Problems with the ignition usually stem from the cps wiring at the cps connector.
Anyways, the output from the ecu to the ignitor is close to 5v and floating ground, I don't think a 3v battery would be enough voltage to trigger it. I looked at the ignitor signals on an oscilliscope a bit when I did my dual ignitor with 1jz coils setup.
isnms said:I am trying to track down why my rpm graph and my dyno results are so jagged. Everyone says it is ignition related. I have changed plugs, wires, cps, coils and set timing per tsrm. I'm down to the igniter.
isnms said:I've reworked the connections at the cps and coil. The ones at the igniter are fine.
But even if I had a wiring harness that is cut in two, I want to see the discrete device pass it's diagnostic test. Any valid test.
sparkplugs.com said:ISO (International Standards Organization) is an international organization which establishes standards for the production of automobiles and there parts. The ISO height for a spark plug from the seat to the top of the terminal nut is 50.5mm (1.98")
JIS (Japanese Industrial Standard) is a Japanese organization which establishes standards for the production of Japanese automobiles and there parts. The JIS height for a spark plug from the seat to the top of the terminal nut is 53mm (2.086")
