Does 1j IAC valve use the same grommet and diaphram as the 2j?
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
I could only order the 2j's IAC valve's rubber grommet and diaphram from Toyota. The diaphram appears to sit flush, but the grommet that sits on top of it was about 2mm too tall. After installation, I can hear air pushing out of the valve when I open the throttle body. I ground down the grommet to sit flush, but it didn't help. Anyone know what's causing it not to seal? Is it because the 1j and 2j IAC components are not interchangeable?
scottiedawg66
Bay Area Ca
AFAIK they are the same. the part number is still a good toyota part number for the 1jz grommet so you might just buy another one at the dealership, they probably have one is in stock, they are about $3.
