do supras need premium gas???
chefma70
404
Florida
cause i read in several places they do. if the car requires premium i think il pass my really good condition mkiii to someone else soon and buy a motorcycle.latley i have been using the medium octain ?90??is this safe for the engine?
anyone in here use regular in their n/a and notice a difference from using premium.rodknock??
chefma70
404
Florida
cool i think i stick with 89 for a year or 2 then decide if i wanna keep her.i hate gas prices so much. DUCATI 848 ftw(sf)<<
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
^ Your two cents adds up at the pump ;)
Assuming the engine is stock you should run what the manual says. All more octane does is allow the knock control system to push the timing a bit. If you want that extra bit of performance go ahead and cough up for it. Otherwise it's a complete waste of money.
Fwiw I've run 87 in my turbo (what the book calls out) for 95&#37; of it's life (21 years) without issue.
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
running 90 octane here in my turbo caused pinging and when i switched to 91 it stopped. my car was a bit of princess though so that might have had something to do with it
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
Most stations around me have stopped selling premium and plus is next. But I still buy 93+. The only time I ran less than 93 is when the dot head pumped in regular after I told him 3 times premium and my car ran like shit afterwards.
I also have a 1jz so maybe its more used to higher octanes.
jessetooslow
551
Tiverton, R.I.
I was running 93, never felt a difference, went to 87 or whatever the cheaper is and it seems to be more peppy with no pinging, I go to the good stations, not the small guys.
mirage83
457
Georgia
Maybe a foolish question, maybe not, but for a newly rebuilt engine should I just stick with 87 octane, or would there be any benefit to the unbroken-in engine if I went to a higher octane for a few thousand miles? Just curious since I'm about to be in that situation and since we're on the subject of gas thought I would ask.
j3pz
still learning
i dont think its a foolish question at all. from what people have said in this thread, running 87 shouldnt be a problem, but for only a few dollars more you can add a little bit of insurance to your build.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
85 (R+M/2) + 17.5&#186;BTDC = :D
I am in Denver, so altitude is how I get away with 85. I don't imagine I'd need anything higher than 87 (worst case scenario 89) to keep things running strong without issues at lower altitudes though.
dumbo
1,911
Albera, Too Far North
octane level is resistance to burn, higher compression=more heat=pre ignition EDIT(detonation, my bad, pre-igntion is hot spots i think a whole different problem) if octance rating is not high enough
has very little to do with preformance, or saftey(unless you need it) bout 9.5:1 prolly should be using 92oct. and 10:1 proll abouve 92oct. correct me if i'm wrong.
and having aluminum heads dissipates heat faster, can get away with lower octance
