between the starter and transmission there is a metal shim which is attatched to the engine and is sandwhiched between parts of the engine and the tranny. if i forgot to put it on, can i just cut off the part for the starter and use it as a shim without the parts sandwhiched between the engine? or will that cause teh transmission to be mounted/aligned wonky. i wanna just get some shears and cut it off to prevent my starter from not fully disengaging. will i be ok if i just cut the part i need?
