do i need to add a map sensor
NeoJester
104
Emo
i put a 7mgte in my NA 89 supra. do i need to add a map sensor to the NA wireing harness or will it run fine without it.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
NeoJester said:
i put a 7mgte in my NA 98 supra. do i need to add a map sensor to the NA wireing harness or will it run fine without it.
7mgte does not use MAP from factory. It has an Air Flow meter , and you may want ot use that if you have no way of eliminating the AFM -
NeoJester
104
Emo
thanks for the input guys, really helps hopefully my car will finally be on the road and properly tuned/running.
boost fiend
852
Rockford, Il
only reason to add a map sensor is if your takigout the afm of going with somthing along the line of a maft pro or other ype of piggyback/stand alone.
im not that far myself yet, but thats what research tells me.
