Do i have the right injectors?
mk3-4-me
669
Milwaukee, WI
ok so when i got my 87 gte supra, the injectors that were in there are yellow. Everywhere i see the yellow injectors, they say its for the 7mge. Idk if its cause its an 87 but what do you guys think? do i have the wrong ones?
Devin LeBlanc
1,830
Las Vegas NV.
Early 7MGE injectors were yellow, Late 7MGE injectors 91+ are green and don't use a injector resistor, All GTE injectors are Black.. You have N/A injectors
bioskyline
1,236
powell river bc
yep you got the wrong injectors.
Stock 7MGE Injector:
Code Number: 23250-70040 Yellow Tip
Overall Length: 2.810"
Injector Tip Length: .260"
Injector Inlet Length: .614"
Injector Tip Diameter: .370"
Injector Inlet Diameter: .416"
Injector Opening:4
Injector Connector: Type F
Flow Rate: 295 cc/min Yellow Tip
Impedance: High 13.8 ohm
the gte has 440 cc/min stock
Volvospy
55
Northern VA
Who would do such a injectors replacement? That's so stupid because not just the injectors, you have to modify the clips also. If you're looking for a set of 440cc, make sure you get gte clips also.
mk3-4-me
669
Milwaukee, WI
no it wasnt a GE-T... the block has all the oil lines and the oil squirters under the pistons... that sucks though... But i have to break the motor in anyways so im not gunna be hitting it, i guess ill have to wait for some 550's now. lol
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
Or MAYBE they're from another car. What color were the Evo 8/9 injectors? Someone mentioned the color the other day for those.
bioskyline
1,236
powell river bc
mk3-4-me;1641609 said:
the clips all fit fine... maybe its cause it an 87? IDK why the PO would put those in...
could be a parts store mix up, alot of times the clerk enters the engine as the non-turbo model. how does it run on the injectors? they could be re-built, just wrong casing color???
440s are bigger and all 440s are black through all the years. N/a injectors are yellow or green like already stated. So you ahve something like 315's or something.
mk3-4-me
669
Milwaukee, WI
damn... when i rebuilt my motor, there actually was a hole in one of the pistons!!! lol so ya i gotta get injectors now... you dont think its safe for just normal drivin.. when i get it drivin?
Compton74
355
Long Beach
Your car no matter what the case will not be getting enough fuel, the injectors are made to only open, squirt the proper measured amount of fuel(440), and close. Your injectors (315) are to small to properly support a 7MGTE. Do not run them, of you'll have one or more pistons with holes in them.
Detonation is not fun!
