Disabling the Hydrofan
speed
Gone. Email me.
May 27, 2006
1,045
not here
www.timduganphotography.com
Ok pretty much this is the only big issue left with my swap. I have a good set of electrical fans that I'll be using, so I don'tneed my hydrofan pump (besides, the motorset didn't come with the ecu, fan, clutch etc). I had a major unforseen expense arise, so if at all possible I'd rather not get a brand new waterpump to replace it. Is there a safe/acceptable way to disable the Hydrofan section? If not, whats the best way of recirculating the fluid/blocking it off?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i would wait until you CAN afford the 2J mechanical pump. you'll be putting alot of stress on the pump due to the fact that a simple tube from outlet to inlet will not be enough to cool it down before it enters the pump. it'll last a good while but its almost certain that it'll burn it up eventually.
i would just wait instead of ghetto rigging it for a bit. but thats my opinion
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
:word8kn: and you are deciding between the hid's and a water pump?:3d_frown:
