Direct Fit 550cc Injectors
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
The time has come to upgrade the fuel system.
I am looking into the RC or Pricision Turbo Lucus injectors but both of these brands require soldering the new clips into the factory harness.
My question is are there any other 550cc injectors sold for the 7MGTE that will simply plug into the factory harness without soldering?
figgie
Twin Cities, Minnesot-ah
RC or Precision Turbo are both Delphi Multec injectors. Hence the need for a new terminal.
You could always buy the ends and crimp them yourself that way you avoid the soldering gun on nickle plated wires which do not take solder to well ;)
MKIIINA
Destroyer of Turbos
Plano, TX
if you can track down some from an FC RX-7 (Turbo II iirc) those are direct fit. Only hitch is you need to find some from 2 cars and should get them rebuilt/cleaned/flowed before installing them. good luck!
