Originally Posted by supraNa1990
the pre 89 dimmer switch is close but not exactly the same as the 89+.
just compare the two dimmer and you will see one and only one of the connector does not plug into the 89+ dimmer if you going from pre-89 to a 89+ switch.
i blew mine out and decided to change my 89+ dimmer for a pre89 and i had to pop out one wire and rearrange it so it can plug into the pre 89 dimmer switch.
if you want to pop the wire out, just get a set of mini screw driver set and use the flat head and press on the tabs in the plug for the dimmer and pop out the wire.
If you confuse - sorry i don't have any pics to show you but when you do it yourself from pre 89 to the 89+ dimmer swap you will understand what i just wrote.
Jeff Lange:
Like I said, it was changed in 1990 in the USA. It was changed in 1992 in Canada. It corresponded to the same year the airbag was added.
I didn't realize the wiring changed, but looking at the wiring diagram, you guys are correct.
Pin changes:
Without Airbag - With Airbag
1 - 2
3 - 1
4 - 3
