digidash fitment
JustinGotA1j
532
Chilliwack
I want to buy a digidash from a 1ggte for my RHD JZA70 and was wondering if all the plugs and wiring were a direct fit or what modifications would need to done for it to work. Thanks
Doward
4,245
Alachua, FL
It says in the post it's a RHD :biglaugh:
You'll need to verify the wiring pin out of yours vs whichever dash you get, as well as sensor input.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
The sender is diffrent it uses a 2 wires analog system or 3 wire digital system there is no way to mod the 2 wire system to work it needs to be replaced with the correct one then you need to tear out the interior and add the three wire system..
Supra Sam
33
Sydney
Yeah I did this conversion on my MA70.
The only thing that didn't work was Fuel Gauge - which you will need a digi fuel sender for.
The difference is the digi sender has 1 arm, and the analog has 2. - it plugs into the existing sender plug.
Do a search theres only a handfull of threads on here about it. In one of them there's a guy in NZ that can source them brand new from Japan.
I got mine recently local in Australia, but I did email that guy, and he still gets them. He quoted me $200- new zealand dollars I think.
Let me know if you can't find the thread and I'll see if I can dig up his email address.
HTH :)
Sam
