hello is R154 and getrag gearbox clutch set different??pls explain in detail
D dannyturbo New Member Oct 4, 2009 7 0 0 gadong Nov 28, 2009 #1 hello is R154 and getrag gearbox clutch set different??pls explain in detail
OneJArpus Supramania Contributor Jul 1, 2005 2,798 0 0 40 Newark, New Jersey, United States Nov 28, 2009 #2 two different transmissions. I would say yes, They are different.
Bigzavs 86.5 1JZ Single Turbo Apr 21, 2005 2,267 0 0 39 Arlington, TX Nov 28, 2009 #3 the V160 probably has 1/2 the splines on the input shaft that the R154 has. R154 clutches will not work at all with a V160, and vice versa
