differnce between 2jzs?
tissimo
Stock is boring :(
Melbourne, FL
Orangeracer;1138732 said:
so i am wondering if there a differnce between a supra 2jz and aristo..
supra 2jzs are dry sump, forged internals, along with a super alloy block thats extremely strong but yet weights only 14 lbs. They also have bigger turbos (capable of near 1000whp with just 14 psi of boost and spool at 3000rpms).
but really the difference between a jdm supra 2jz and an aristo 2jz is the oil pan pretty much (besides the obvious different harness).
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the turbos are different
now if you mean a usdm vs jdm there are bigger differences
Flateric
946
Calgary, Alberta, Canada
I've heard the cams are smaller also for JDM's and smaller injectors, ceramic turbo rather than steel (less durable I'm told than the US version)
JDM motor's only speak Japanese with just a little slitly bad engrish.:icon_razz
annoyingrob
Boosted member
Jul 5, 2006
2,304
JDM vs USDM,
only one of the cams is different. Intake I believe. 440cc high impedance vs 550cc low impedance injectors, MAP based instead of MAF based, ceramic compressor wheels instead of steel..
As for the aristo motor vs Supra, the sump is different, and I THINK they use slightly different turbos, but I would have to look at the twins I have to prove that.
