Differential or Driveshaft?
mecevans
1,295
M-bay, cali
I have a few issues with my sup that i need to address. first off it this vibration from the tunnel / rear of car. only happens after 20mph and vibrates at different frequencies after that. My differential has about 1/8 to 1/4 of slack from the input shaft. It get's annoying to drive because it "clunk's" that 1/4 of a turn when i drive during takeoff, pressing in the clutch , shifting, clutch kicking, etc. i checked to see if my DS is twisted and it looks all good.
W58 and drive shaft from donor car
4.3 lsd rear end
where do i start?
airhead04
1,489
Lima, Ohio, United States
Start where jdub said. My center bearing did that clunk noise, then went bang:biglaugh:. Needless to say I have a new d shaft. There is video of the noise from my car on here somewhere.
dealer only iirc. i know the auto zone one the tabs are in the wrong spot and would have to be cut and welded in the right spot or your drive shaft angle will be wrong.
turbo87targa
482
colorado springs
jdub;1479466 said:
Have you checked the center bearing?
I have a very similair clunk during takeoff and shifting (basically anytime I call for a raise in rpm) but I have a 1 piece aluminum ds. It sounds exactly like someone hitting two pipes together. But I have no real vibration until 80mph... So my only guess is my diff.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Or the uni-joints. If you are getting vibration from a one piece DS, it's out of balance or it does not have a damping tube inside (or both). Typically a one piece will have a natural resonance that becomes obvious at 70-80 MPH...they all have some vibration on this car due to length. A well made one will minimize the effect. Who made it?
gofastgeorge
944
Texas
Could be half shafts, or your diff housing mounts.
Pray that it isn't your subframe (cracked).
turbo87targa
482
colorado springs
Well Once again jdub is amazing. That clunk was my ujoint slowly being ripped off. Attempting to find who made the shaft failed (all I know is it's from a group buy from a 1st batch of lighweight ds's, previous owner bought)
brought it to Toyota to see what they thought and they referee me to a machine shop who's rebuilding it for about $120
mecevans
1,295
M-bay, cali
my auto DS is gone. i think it got tossed out. i called a DS shop nearby and they say they need a measurement. something about a flange. will it be easier to ust bring in the 2pc from my car?
