Differential Differences?
Wich Differential Would you Use to Drift?
  • Total voters
    5
MA70witBoost
Registered Drifter
Ok, I would like to open up a discussion on differentials... Im looking to replace the differential i have. My Pumpkins Oil Seal is leaking gear oil and who know's what damage the diffs gotten in its 20 years in existance. What are the differences between the differentials bellow? I know about the 1 way, 1.5 way, and 2 way LSD stuff... But Selective, Mechanical, and Helical LSD?? Heard the terms befor just not familiar with them. I plan on getting the MA70's known in the drift scene... Just trying to see what helps me out with that. :thefinger
hawk
save me from my camry!
Jul 19, 2005
28
cape coral, fl 33990
well i know for a fact that the selective lsd uses clutch discs stacked in different arrangments to create different settings. ie. higher or lower initial torque. i also hear that they need to be rebuilt qutie often from what i under stand and my whatings of best motoring videos and the like.
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
The torsen diff indeed reduces understeer, but does not lock up hard on braking. If you like to turn in sharp and then power out, it does a good job of reducing front understeer and the putting the power down evenly. I like to slide all 4 wheels and lock the rear end on braking so it doesn't work as well for these high-speed dynamic moves.
Selective diffs allow for a change from open to lock, 1.5 way to 2 way or differing hardness.
Torsen is helical.
I'm not sure what you mean by mechanical
Red Dragon
Keep That on the Down Low
Jan 5, 2006
318
Austin, TX
3p141592654 said:
You can start with this paper that explains the Torsen in great detail and compares to conventional differentials. It is by no means the nice tight summary you are asking for, but if you put in the effort you will come out knowing a great deal more about what a Torsen diff is all about.
http://www.torsen.com/files/Traction_Control_Article.pdf
holy crap, I got thru the first two pages, will read the rest when not at work... thanks, looks informative
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
Not to jack the thread, but if i were to change from 3.73 to 4.30 lsd, what would i have to change for my speedo to read correct?
