different turbo different elbow??
PorterzSupra
703
Hebron CT
I am going with a T4 turbo but do I need to buy another elbow or does it come with one? Where are you suppose to buy them? I need it to go from a T4 to the stock downpipe bolt pattern
N
NDBoost
Guest
from what ive seen the T4 turbo isnt bolt on, someone correct me if im wrong :)
supra90mkiii
227
Racine, WI
if you can, post a picture of the exhaust side. it might be an externally wastegated turbo, which would mean you need a different exhaust manifold. and would also mean you would need a v-band style downpipe, you could try gettinga local muffler shop to make something for you... i'm not sure, i'm still on the stock turbo.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
correct.
You have to either tell us the exhaust flange style, or give a picture. If you bought a regular T4, I assume it's most likely a 4 bolt flange (flat circle where there are 4 holes, and dp attaches flat to the circle).
We need a pic to better help tho.
eric
Tell us which of the pics it looks like. I have attached a few pics of common housings.
