Different intake plenulum
8,897
They are the same size, and feed the same runners. Your car would be sluggish under 4000 rpm, then be normal after that.
SRZMK3
the 2jz na intake has a completley different head size so the bolts wont line up. the cressida doesnt have the y pipe which the supra does to increase horsepower by allowing more air volume before the manifold, and the fact that it has acis.
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
DEFIANT 7M
Nashville/Miami
mshaw067;1795398 said:
Would I get any gain in power if I changed my intake mani to the cressidas.
To answer your question, I would say no. But don't give up.. Try different set ups, you wont actually know what works and what doesn't until you try.
AJ'S 88NA
2,419
Florida
Unless you have a lot of other mods a bigger TB wouldn't help much. I have 2 60mm TB's on mine with a lot of mods.
FFIM would elimate the ACIS don't think it would produce much gain.
mshaw067
k what throttle bodies are you running. Also does the maf-pro just wire up in place of the factory computer, and the AFM. or weather vein as it has been called. Also does it control timing and injector pulse and all that jazz. I am looking to do some major upgrades in the next month or so, The bottom end and top end of my motor are fully built. I am also running BC stage 2 264 cams.
DEFIANT 7M
Nashville/Miami
mshaw067;1799926 said:
ya but i still want the maf pro. all i want to know is does it plug up and replace the stock computer.
Not quite that easy. Your not going to get an easy answer either. Gotta do some research on your own, you will get help here. But if it seems you (and I'm not saying you per say) want to be spoon fed with out contributing to your own questions. Well lets say things won't turn out good.... And no it will not plug up and replace the stock computer, more info here http://www.supramania.com/forums/showthread.php?40255-Archive-MAFT-Pro-Questions Good luck
8,897
SRZMK3;1797141 said:
i think that unamed change was the creation of the 7m crank instead of the 6m they used.
I don't think so. The Supra went from 185 lb/ft to 188 lb/ft of torque. Or something like that. I don't recall the torque of the Cressida off the top of my head. And a slightly heavier crankshaft woulnd't net more power.
