What is the difference between these 2 turbos? I am trying to buy a 60 trim but I understand that the 60-1 is VERY unreliable so i was wondering if anyone had any experience with the 60 trim and whether or not it is reliable. Thanks
Albert;1825795 said:People are misinformed. The shaft is too "small" but based on what? Garrett's shaft that the turbo sits on is smaller than a ct-26. So it has nothing to do with that.
They are unreliable IMO because you're putting a bigger wheel up front than stock, more weight= more momentum, so when your shitty ass BOV doesn't work properly, causing compressor surging, the wheel spins back an forth violently putting stress on the shaft and possibly snapping the shaft.
What's funny is I've seen numerous of Garrett 60-1 shafts snap as well due to the same issue.
Garrett uses the same shaft (p-trim) for their tiny 57trim turbo wheels, and 60-1, 62mm, 67mm, 70mm wheels, and the p-trim stays the same. So this "shaft is too tiny" nonsense is retarded.
If your gonna upgrade a turbo get a good BOV an get the exhaust clipped IMO.
I've sold 20+ 60-1 ct26 upgrades, not a single one has come back. But every single one of my customers listened to me.
Albert;1826920 said:Your question is confusing. .ar has nothing to do with a wheel.
Can you clarify?
IJ.;1827029 said:Huge mismatch between Turbine and Compressor = Surge Monster, as Albert said most people have the PoS stock bypass valve, T04Z is a good example of a Surge Monster you need to run a very active BoV...
