Difference between car/truck and trailer tires?
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Just picked up a 6.5x12 Bri-mar single axle trailer for my landscaping business. It needs tires, it has the standard white trailer rims with st205/75R15 trailer tires on it. So the question is can I go to the junkyard and just grab a couple 205/75R15 tires off a car or truck, or do i need trailer tires, if so what is the difference between the two? If anything i would think the car tire would be superior.
Thanks in advance for your input guys!
DannyMK2
Long Island
i think its a funky tire size and it might be tough finding them at a junk yard. though, car tires would probably work, and i have seen it done before, i think the main difference is that trailer tires have much stronger sidewalls. the biggest reason i would say not to do it, is in case you ever had a blowout that caused an accident or even if you were to get stopped by the DOT, i would think it would be a ticket for not having the proper tires. not 100% sure though. this thread makes some good points:
http://www.wmi.org/bassfish/bassboard/trailers_towing/T12572.htm
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
I did some quick reading, so don't flame me if I get some details wrong...
Yes, trailer tires are different... but like car tires, they come in radial flavour and bias-ply flavour, and don't mix the two.
I think whether or not you want to use a car tire depends on what you're pulling. If it's a light load, car tires should be ok. If you're loading it down to the max and yanking it across the country, get the good ones. 205/75R15 tires likely never came on a vehicle over 3000lbs, so putting them on a trailer for 5000lbs and then towing it at highway speed is asking for trouble.
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
yes they are definatly different. trailer tires have a non agressive pattern that wont grab ruts in the road, they also have thicker sidewalls for both loadbearing charecteristics and tracking properties. get the right tire so you are not a hazard to us all.
lowes, home depot, and most tractor/farm stores have them already mounted for less than 60$
