Diff problem?
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
Are there known issues with the differentials and if so how difficult are they to rebuild say in comparison to a ford 8"?
After replacement of the bearing with no change at all in the noise, what I though was a bad wheel bearing I am thinking might be a noisey diff. I found the pitch changes between accel and coast, is speed related but not load sensitive i.e. it doesn't change when turning left or right. Also, I am now begining to feel a roughness that eminates from the rear through the cabin. My second thought would be the center support bearing but when I checked it there was minimal if any play in it.
ians13
537
Jacksonville, fl
sounds like pinion bearings, i just pulled my diff apart notting hard about it. you need a press to change the bearings, and a axel puller. if you had all the parts it would take about 4-5hrs to pull the diff rebuild and reinstall.
good luck.
