Diagnosing Rod Knock
Supracentral
10
I thought I would repost something that I posted up on my site back in 2004:
Diagnosing Engine Noises can be the most difficult thing a mechanic can do. Misdiagnosis is the norm rather than the exception.
I almost laugh when people open up and say it's a "rod knock" for every noise from fuel pump rattle to rocker arm tap.
My personal favorite was a customer of mine who insisted he had a rod knock when in fact a bulge in one of his tires was hitting a shock absorber.
You might not have enough money to send your kid to college after you spend it fixing an audio illusion. On the other hand you may spend dozens of hours and hundreds of dollars replacing parts in an engine that is truly shot.
First thing you need to do is spend 20 bucks for a cheap stethoscope at the auto parts store or if you are going to do this a lot get the electronic ones from Steelman for about $160.
But, possessing human nature, you will convince yourself that a hose stuck in your uneducated ear will do just as well. No sense in arguing with you that the whole idea is to be able to discern infinitesimal changes in direction and intensity that require the use of two somewhat experienced ears AND the right tools.
So stick your dumb ol' hose in your stupid ol' ear and we'll start with some clues.
Remember that diagnosis of engine noises is nothing more than splitting possibilities down to only one
First off, eliminate all of the accessories like the alternator, power steering pump, A. C. compressor and vacuum pump by removing the belts one at a time. If the noise is gone, of course the problem is a belt driven accessory. If the naughty noise is still there you should be able to hear it more clearly by not having the accessories whirring away.
If the engine has a carburetor instead of fuel injection it probably has a mechanical fuel pump mounted to the engine. Before the engine gets too hot, put your hand on it. If it is making a noise you should be able to feel it.
Try to track the noise down with the stethoscope tip or the end of the hose suckered onto the engine surface, sealing the end. Spend a full ten minutes putting the hose all over the engine, not just where it is loudest. Try to envision the parts moving inside the engine. You are training your ear, not just listening, so don't get in a big rush except to be sure that the engine doesn't overheat. A trained ear can tell you which piston is slapping or which rocker arm is clacking from outside the engine so if you come out from under the car proudly saying, "it's the bottom end" get your dumb-ass back under there until you can tell me it's coming from the oil pump or the 3rd piston back on the driver's side or the flywheel or the camshaft.
Rod knocks are loudest at higher speeds (over 2500 RPM) Feathering the gas pedal may result in a distinctive back rattle between 2500 and 3500 RPMs.
Bad rod knocks may double knock if enough rod bearing material has been worn away allowing the piston to whack the cylinder head in addition to the big end of the connecting rod banging on the crankshaft rod journal. It will sound like a hard metallic knock (rod) with an alternating and somewhat muffled aluminum (piston) klock sound.
Wrist pin knock in modern engines is very rare today but is a favorite for the misdiagnosticians.
Determining which cylinder contains the noisy parts may be aided by shorting out the plug wires one by one with a common low voltage test light. Now you won't get the bulb to light up but it is a convenient way to short the cylinders without getting zapped or damaging the ignition coil.
Attach the alligator clip to a convenient ground, away from fuel system components, and pierce the wire boots at the coilpack or distributor end of the wire.
If the noise is changed when the plug wire is shorted to ground, you can figure that the problem is in the reciprocating bottom end parts. (piston, wrist pin, connecting rod or connecting rod bearing)
The reason the sound changes is that when you short the cylinder plug wire you are stopping the combustion chamber explosions that are slamming the piston downward making the inside of the big end of the connecting rod bang against it's connecting rod journal. Or in the case of piston slap, no explosion changes how the piston is shoved hard sideways against the cylinder wall.
If you get a change in the sound when you short a cylinder out it may become moot as to what the problem is because the oil pan and cylinder head must be removed to correct the problem. [Generally speaking, an engine with damage to reciprocating parts (pistons, rings, connecting rods, wrist pins or rod bearings) and more than 70 thousand miles is not cost effective or risk free enough to attempt to repair. Replacing a crankshaft, for example while the rest of the engine has 70k perfectly maintained miles on it is risky enough but whatever killed the crank has scored the rings and packed the lifters with debris and smoked the piston pin bosses etc.]
If the sound doesn't change, look at parts other than the reciprocating ones. In many cases of rod-knock or piston slap, more than one is banging so even if you eliminate the noise from one rod the other one will still be a-banging away with a different, more singular tone.
N
NDBoost
Guest
very good post +1 for this info, im going to add this to azsupracentral.com forums under tech info.
N
NDBoost
Guest
hmm, once again another worthy post, this will be added as well. Of course both given credit to you :)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Good post. I have an electronic steth that wasn't very expensive. Especially good for finding bad alternator and idler bearings long before they show up otherwise. And if I remove the tip I can listen to what the neighbors are saying from hundreds of yards away ;)
N
NDBoost
Guest
so who killed kennedy?
I have a "theory" on RK with rebuilt motors.
I've posted this a few times when this pops up here.
My take on it is once the crank is cut to 2nd undersize you're through Toyota's hardening so the crank isn't resistant to scuffing the bearings and picking up material.
A few cold starts and you've increased bearing clearance enough to start the vicious cycle of more clearance>less pressure>more wear and RK is inevitable.
I believe this enough that for my motor I had the Crank Heat treated then Niterided before the finish polish.
wh0wants2know
55
seattle
good writeup, I learned some stuff. Something else to remember: If you have an electric fan, those make all kinds of noises, so turn it off too (but watch for overheating). Also, if you have two electric fans (i.e. FAL), then they spin at slightly different speeds, and they will have some sort of resonance at a specific frequency and it will sound like a thrumming sound that has a regular pulse to it but doesn't match up with the engine speed and it sorta sounds like it might be some sort of rod knock if you've never heard rod knock before.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Lol, I wish I knew. I said I can hear them, I can't undertsand them. I live in Cali so I don't speak Indian, Chinese, Pakistani, Vietnamese, on and on. I only speak English and Russian ;).
Ian, do you know what method is used to case harden the 7M crank? Nitriding? Is so yes, nitriding is very thin and you might be onto something.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Interesting. I wonder what they do. I thought the case was deeper using induction but I'm not sure. Fwiw, the cranks used in piston powered airplane engines are nitrided and that's only about 4-6 thou deep. Them babies run at either 100 or 75% power for hours on end and the clearences are real sloppy even when new compared to a car. But you're right, if the machine shop is breaking through (or coming close) the journals need to be nitrided again or problems will likely occur.
Induction depends on how much Juice they give it so cost becomes a factor Niteriding is much cheaper.
Pretty sure after 2nd US you're down to the soft and if it's niterided you would be after 1st US :(
Someone posted awhile back in one of these discussions that Toyota don't recommend going under at all so I suspect it's Niterided.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I dunno, one needs a sealed furnace and ammonia for nitriding so it can't be all that cheap. I kow lots of cams are induction harded though. I wonder if some of these knocks come from head gasket problems? As you know, nothing kills bearing quicker than coolant in the oil.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I can guarantee that some of them are from BHGs. And water in the oil is only half the problem - the exhaust in the coolant before it hits the oil makes for corrosive oily slush... about as bad as you can get for bearings without actually pouring acid into your oil filler.
jimi87-t
1,127
5
Colorado Springs
Another thing I think could lead to problems is, not primming your oiling system after doing an oil and filter change. When I change out my filter (just did one tonight BTW) I fill it about half way or more with oil and then install it (GTE), I then prime it, it still took about 20 sec to see PSI. So if you don't prime your system after doing an oil change, thats about 20 sec or so with no good amount of oil on the crank.
jimi87-t
1,127
5
Colorado Springs
GrimJack said:
I can guarantee that some of them are from BHGs. And water in the OIL is only half the problem - the exhaust in the coolant before it hits the oil makes for corrosive oily slush... about as bad as you can get for bearings without actually pouring acid into your oil filler.
Fixed
