DIAg test on my 87 turbo 5 speed
87CandyBlueT
553
Kentucky (NKY)
I just used the Super Monitor to retreive the engine codes. I have no idea what these mean if anyone could please tell me what these codes are and how to better read them and are all these necessarily bad.
Any help would be greatly appreciated.
ENG -
ENG-21
ENG-51
ECT-00
C/C -
A.B.S. 00
All these codes were read off in that order.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
the 21 is oxygen sensor and the 51 is a/c switch or neutral start switch the others i dont know. they are in the 6-4 section of the haynes toyota repair manual.
87CandyBlueT
553
Kentucky (NKY)
Can you tell me what they are when they are blank like no numbers like this
ENG -
ECT -
ECT - 00
what does the 00 mean?
A.B.S.-00 (guessing anti-lock brakes but the '00'?)
Do you know what C/C - stands for?
87CandyBlueT
553
Kentucky (NKY)
Okay i removed and re-inserted the EFI 15amp fuse. Now I have the engine code ENG-51 still. I also read on the site from above that it could a number of things including the TPS. Could this (not the TPS) but the actual problem with A/C switch be whats making my vehicle idle high and jerky when shifting gears.
87CandyBlueT
553
Kentucky (NKY)
Yes the A/C isn't hooked up in my car, the condenser and everything is their just to drive belt ran to it. I ordered the hard (heater type) hose that runs from the ISC valve, because after changing my ISC valve the hose split at the end by the 3000 pipe. It may be what caused my high idle but still not sure.
