decking? Reliability and BHG?
Carl Johansson
33
fresno Ca
So i know decking increases compression of the engine. I run an 88 7-MGE with maual trans in the 24 hours of Lemon series. I am wondering what decking would do for power - but much more importantly, does it reduce relaibility and longevity of the engine, and particularly does it make a BHG more likely.
We have to keep these things on the track for 14- 24 hours, so far the engine has been stone cold reliable - with over 200 hours of racing, without ever opening up the motor. But if we go the decking of the head route - what are the reliability consequences?
Carl Johansson
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Are you running stock HG now? You could deck the block, machine the head and go with a good MHG and be ok with a little more compression, but you really shouldn't take much off the block or head. There are right ways to increase compression and taking material off the block/head is not one of them. Also, like SRZMK3 said, you'll have to run 91/93 pending your altitude. Gains would be minimal.
I would go through all that work if you're really after power. If you want to make it more reliable by using a MHG instead of a stock gasket, then ok.
Carl Johansson
33
fresno Ca
Thanks guys,
we have had zero problems with the stock head gasket - 15 races, over 200 hours of road course racing , never once a head gasket issue - in fact, we have never opened up the engine except to put in ARP connecting rod bolts after race #1, since then it has been gas and go!
as for decking - seems to be lots of added potential problems for very little gain - we will stay stock - can't argue with results!
Carl Johansson
sylquebec
167
Quebec
look like your 7m is strong, I would not do anything to it.
Carl Johansson;1784163 said:
Thanks guys,
Carl Johansson
