For those that don't know, the dashpot is a simple diaphram that uses a valve to let air in quickly, but release it slowly, easing the throttle plate closed when released over a very short period of about .8 seconds.
I have a 1" GFB brand blow off valve recirculating into the accordion hose, like the stock setup, but it moves a lot of air and I still get the spikes in rich fuel and the engine stumbling/stalling effects of a BOV vented to atmosphere.
I thought that the dashpot, set higher, and releasing the throttle much more slowly, would be the ideal solution for me, and all the other people who vent their BOV's to atmophere on the stock AFM system.
What if I could find a different VTV valve from a different car with a similar system, that releases the air over 1.5 seconds? I think a 1.5 second release time would be the best solution to help burn the rich fuel spike when letting off the throttle. Any suggestions on a VTV that might do this? Maybe one from a larger truck throttle body would have more resistance? It's just a simple valve that plugs into the vac line on the diaphram, and could be installed in no time flat!
I tried 2 of the OEM VTV's in series, but it did not slow it down.
