Edit: I have got over this hurdle now, but found one last group of wires. See post #10.
Edit 2: I figured out the last group of wires (see post #17). No more issues that I can see right now, though I'll probably run into something again after I get a bit further.
Edit 3: Another question in post #18.
Edit 4: Support bar is out. I may have more questions later, we'll see.
Edit 5: Tackling the white boxes now, see post #27.
Edit 6: Box with the heater core is out, additional inquiries in post #30.
I've been following the TSRM for removing the safety pad. However I've come to the step that says:
"Disconnect the driver side wire harness connectors"
"Disconnect the passenger side wire harness connectors"
"Disconnect the console box side wire harness from the body"
The pictures aren't very specific or helpful here, so I'm not exactly sure what I should be disconnecting. Also, the connections are very tight, is there a trick to getting them apart?
I'm attaching a picture from behind the glove box with the connections I see circled. I took a picture under the driver's side too but it didn't turn out very well.
