dash cluster help!!!
AZN MK3
341
Now in the U.S.
yea ppl where telling me that i have to change my cluster harness because it wont work for sum reason. if im goin frm a n/a supra to turbo i was wondering if thats true.... and im going 1jz on my car...
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
I dont think you should have any problem with that as you will still use your same cluster, but you will need to either swap in the tach from the clip if it still functions properly (mine didnt) or swap a turbo tach into your current cluster.
AZN MK3
341
Now in the U.S.
iite thanks man.... also do u knw anything bout drive shaft, meaning is the automatic drive shaft longer or shorter than the manual one???
