i took off accordian hose and found like 1mm of shaft play in my turbo. i wasnt shure if it was allot but when i idle i cant tell if this rattling noise is my heat shield or shaft play. when i hit full boost i can also hear a louder rattling from turbo. but then evens out past 3500 rpm. for those of you who have gone through shaft play is there a way to slow down the deterioration, what other problems will it cause.
