Dang Turbo.
1_slo_92
145
Hillsboro Ohio
Ok so Im working on taking my turbo off and HOW MANY DIFFERENT THINGS ARE THERE TO DISSCONNECT?!?! I got 3 bolts to the dp, (no elbow, dp replaced it) 4 bolts on the mani, Oil line (drainback line?) to the block, im working on dissconnecting that weird looking metal pipe, almost like a small metal accordian pipe, on the bottom of the turbo but I can't seem to get all the bolts:cry:. Anyone have any suggestions? O and also I got the bracket dissconnected on the bottom of the turbo.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
well you have the oil drain (acording lookin thin on bottom side of turbo,
this is easiest to remove from the block,
then you have the oil feed, which is bolted to the block down below the cps area. about 6 inchs above the pan
you have the water lines.
4 bolts to the manifold, and should have 4 bolts to the down pipe.
1_slo_92
145
Hillsboro Ohio
well how many bolts are on that accordian thing? I have taken 2 or 3 out and can't find anymore but it won't come unbolted. Also I had a bracket on the bottom of the turbo I think it was 1 bolt to the turbo, 2 on the block.
